Use ACE Ethernet port entries so that the filter looks for traffic on specific ports. You can only insert an ACE Common Ethernet port for VLAN ACL types.
- The ACL exists.
- The ACE exists.
- SelectAdvanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select Eth.
- Select the Port tab.
- Select Insert.
- Specify the operation type.
- Select the Port ellipses (...).
- Choose the ports.
- Select OK.
- Select Insert.
Port Field Descriptions
Use the data in the following table to use the Port tab.
| Name | Description |
| AclId | Specifies the ACL ID. |
| AceId | Specifies the ACE ID. |
| Oper | The eq parameter specifies an operator for a field match condition: equal to. |
| Port | Specifies the port or port list on which to perform a match. |
